TwinTurbo.NET: Nissan 300ZX forum - Hello???? The Det sensor output from the ECU you asked about
Subject Hello???? The Det sensor output from the ECU you asked about
Posted by twinturbineZ on June 03, 2008 at 5:03 PM
  This message has been viewed 123 times.
In Reply To what should be 2.5 volts? and would the car still run with a posted by keffboyer2000 on June 03, 2008 at 04:47 PM
Message The ECU may not be bad...just the DET sensor output could be bad. Car should still run fine..even if that's so..Did you run self diagnostics? If the LED blinks 5 times slow and 5 times fast..all is supposedly well...at least that the ECU monitors.
Sounds like it could be a fuel problem..could be bad pump..fuel filter...fuel pump controller..or could be spark related..which could be bad connections or corrosion at the PTU..
So I'm having this dream! I'm in my Z and these guys are after me, but they can't catch me...So they get a car, but they still can't catch me. So they get a plane, and just as their about to catch me....the TWIN TURBOS KICK IN!
