TwinTurbo.NET: Nissan 300ZX forum - still trying to narrow down some problems with car
Subject still trying to narrow down some problems with car
Posted by keffboyer2000 on June 02, 2008 at 9:53 PM
  This message has been viewed 130 times.
Message well came across a few issues i would like to get some advice for. After testing the fuel injectors from the main harness and getting get ohm readings for all them. I decided to test some other pins like #23 detonation sensor, #26 and #27 Airflow meter, #25 Wastegate valve control, and #18 fuel pump relay. The Main concern would be that the detonation sensor inside the engine bay is clearly cut and not connected but i got no ecu code from the computer for this so someone said there might a resister connected somewhere along the line couldn't find anything. When i tested pin #23 Detonation sensor i got nothing. So My question is why would the ecu not show a code? Could the ecu be damaged?
