TwinTurbo.NET: Nissan 300ZX forum - Re: compression test results
txq45
on June 02, 2008 at 5:56 PM
posted by pearlyellowtt
on June 02, 2008 at 05:49 PM
Compression is good enough.. like you said a little low on #6
Check for blow by. Check the hoses in the valve covers that go to the air duct tubes..Or you could even remove the air duct tubes and look in the inlet and outlet of the turbines
pearlyellowtt
17:49:39 06/02/08
Re: compression test results -
txq45
17:56:57 06/02/08
Re: Re: compression test results
pearlyellowtt
18:11:27 06/02/08
False, but it sounds like your turbo's are going. (n/m)
MixManMash
11:05:40 06/03/08
Do you run test pipes? If so install some hi-flow cats and I
Audioquest
13:24:38 06/03/08
i do in fact i installed them when i replaced the engine
pearlyellowtt
15:48:30 06/03/08
