TwinTurbo.NET: Nissan 300ZX forum - My #5 cylinder is still not working?
Subject My #5 cylinder is still not working?
Posted by Fly-Surf on May 31, 2008 at 9:26 PM
  This message has been viewed 150 times.
Message 1990 TT.
Driving to work the engine got "rough". I found the #5 injector ohming at over 30.
I replaced the injector (with one ohming at ~13). That didn't make the car run smoother so I replaced the highly fragile and corroded connectors (injector and coil) for that cylinder...it still isn't runing smooth. While idling, when I pull the connector to the coil/plug for the #5 cylinder NOTHING happens (idle does NOT get worse)...which means that cylinder is still not firing.
Can I check the electical with the electrical pulses to the coil and the injector while the engine is idling witout damaging the electronics?
How do I use my multi-meter to see if the injector and the coil/plug are getting signals?
What should I be looking for?
Thanks
