TwinTurbo.NET: Nissan 300ZX forum - Even if they are reversed from original to new..
Fly-Surf
on May 31, 2008 at 7:55 PM
Yes, thick to thick, thin to thin is the recommended way (n/m)
posted by 300ZMang
on May 31, 2008 at 06:34 PM
Original and new connectors are opposite.
Do injectors have "polarity"?
Replacing injector connector...colors wires
Fly-Surf
18:11:54 05/31/08
Doesn't matter..it's a/c voltage (n/m)
twinturbineZ
18:19:46 05/31/08
Okay...on the relacement connector 1 wire is larger
Fly-Surf
18:22:06 05/31/08
300ZMang
18:34:58 05/31/08
Even if they are reversed from original to new.. -
Fly-Surf
19:55:17 05/31/08
No, it doesn't matter. It will work either way. (n/m)
Woody75 (Denver)
22:15:50 06/01/08
Actually it's pulsed DC. (n/m)
jzack
23:27:51 05/31/08
you're correct (n/m)
twinturbineZ
23:37:49 05/31/08
agreed. the corrosion issue that occurs with the older
robo (sebring1970)
23:53:34 05/31/08
If my half-moon ruber insulator has a thin metal plate
Fly-Surf
06:06:36 06/01/08
I believethat's your problem (n/m)
twinturbineZ
15:34:03 06/01/08
To clarify...I believe if the pin is depressed the
twinturbineZ
17:06:13 06/01/08
I dunno. I have some serious knowledge gaps there.
robo (sebring1970)
21:09:11 06/01/08
The plate should be glue to the rubber isolator - when new
17:40:38 06/03/08
Thanks...good point...
Fly-Surf
14:01:17 06/04/08
Sure. (n/m)
23:10:56 06/04/08
I installed the 2nd injector :-)
Fly-Surf
09:39:19 06/05/08
Fly-Surf
09:52:19 06/05/08
Excellent. (n/m)
23:03:56 06/05/08
