TwinTurbo.NET: Nissan 300ZX forum - Get it behind the hardlines. Starting on the drivers side
Subject Get it behind the hardlines. Starting on the drivers side
Posted by Marc (NJ) on May 30, 2008 at 10:13 PM
  This message has been viewed 149 times.
In Reply To Replacing efi harness and got a ? posted by RedTTZ91(OK) on May 30, 2008 at 09:24 PM
Message feed the firewall boot behind the lines and the snake the harness across to the pass. side. Depin the white connector and make sure to write down where every wire goes back in. Tape up the blue connector along with the black plastic wire cover. I then sprayed the taped section w/WD40 to help it slide thru the firewall it helped alot slid down thru in 2 minutes.
