| Subject |
It's a matter of how much air the pistons are sucking in, |
| Posted by |
zellamay on May 30, 2008 at 10:33 AM |
This message has been viewed 100 times. |
| In Reply To |
Noob question about boost/vacuum posted by FuerGrissa on May 29, 2008 at 10:59 PM |
| Message |
versus how much air the turbos are pushing in. When you are not on the gas, say cruising at 60 mph, the turbos are not pushing much air in, so the vacuum/boost gage will tell you there is a vaccum from the pistons sucking the air in, just like a non-turbo car. Then as you slowly give it gas, you will see the turbos start to supply more air. When the guage is reading "0", the turbos are pushing air exactly the same amount as the pistons are sucking air. When the guage shows you are going into boost, it means the turbos are now pushing more air than the pistons are sucking. This is where the fun of having a turbo starts.
| Follow Ups |
Post a Followup |
