TwinTurbo.NET: Nissan 300ZX forum - After plenum pull, engine chugs and makes whistling noise
Subject After plenum pull, engine chugs and makes whistling noise
Posted by Shortman on May 28, 2008 at 11:43 PM
  This message has been viewed 225 times.
Message I just pulled the upper and lower plenums on my 93 turbo Z to replace the valve cover gaskets and the detonation sensor (knock sensor), but now when I start the car, the engine makes a chugging sound and I can hear a whistling noise coming from somewhere between the engine and the firewall. The engine will run for about 20-30 seconds and then will peter-out and die unless I give it some gas.
I have double checked all vacuum lines and electrical connections and am pretty sure I have them correct.
I am thinking that it must be one or more of the following:
1) Vacuum leak
2) Plenum gasket(s) torn or improperly mounted. I did have to slide the upper plenum gasket a bit to get it aligned and the rubber seal wasn't entirely attached to the gasket in a couple of places (since I had to seat the plenum twice).
3) Bad electrical connections to the IACV, etc. There are 3 of those injector-style connectors on the rear of the plenum and all are slightly corroded. I cleaned them up as best I could. Would any of these cause or contribute to these symproms?
Any ideas on how to narrow this down? Is there any way to test the plenum gasket integrity?
Thanks!
