TwinTurbo.NET: Nissan 300ZX forum - Yes, search on 'dremel method' for the injector
Subject Yes, search on 'dremel method' for the injector
Posted by SilverTwin(OH) on May 28, 2008 at 9:53 PM
  This message has been viewed 124 times.
In Reply To swapped motors, possible to get injector out posted by zsnailpower on May 28, 2008 at 09:30 PM
Message Sounds like you may have one failing on cylinder #1 as well. Have you ohm tested the injectors to verify failure?
Hard to say on the noise from the timing belt area without a little more info. Was the belt recently changed? If the tension was set too tight it will whine.
'91 TT
Stage ??
