TwinTurbo.NET: Nissan 300ZX forum - no more code
no more code
tsaitang
on May 28, 2008 at 2:19 PM
Not sure, I never tested it like that. But I was able to
posted by ThunderZ
on May 27, 2008 at 08:50 PM
alright! finally no more code but still 8 psi boost! now what next!! leaks.....
8 psi boost
tsaitang
07:04:28 05/25/08
Run an ECU diag and see if you have any codes 1st.
ThunderZ
07:38:20 05/25/08
Do a boost leak test. You may have one or more
Audioquest
10:03:44 05/25/08
Re: 8 psi boost
tsaitang
18:45:43 05/26/08
If the 1M OHM resisitor is good, the problem is most likely
ThunderZ
22:22:53 05/26/08
Re: If the 1M OHM resisitor is good, the problem is most likely
tsaitang
08:49:16 05/27/08
ThunderZ
20:50:49 05/27/08
no more code -
tsaitang
14:19:13 05/28/08
Alright, way to fix the codes. Now I'd do what Audioquest
ThunderZ
21:40:10 05/28/08
