TwinTurbo.NET: Nissan 300ZX forum - And if not the heads, what about pulling the plenum off?
yobobrox
on May 28, 2008 at 11:23 AM
The point is its alot easier to
posted by RedTTZ91(OK)
on May 28, 2008 at 11:08 AM
Anything to save some time.
Know any reason you can't pull a short block out?
yobobrox
19:37:50 05/27/08
No reason at all, if that is what you want to do, it
Fast300
19:58:17 05/27/08
What's the reason? Wouldn't it be a lot less labor
Audioquest
21:08:04 05/27/08
Well, if you're replacing the short block...
yobobrox
10:39:45 05/28/08
What is the shop doing for you? (n/m)
13:58:35 05/28/08
See below. (n/m)
yobobrox
14:35:20 05/30/08
Re: Know any reason you can't pull a short block out?
WazTTed
22:09:30 05/27/08
You must of never attempted to pull the heads
RedTTZ91(OK)
00:07:53 05/28/08
RedTTZ91(OK)
11:08:23 05/28/08
Did you read my follow-up?
yobobrox
11:23:10 05/28/08
And if not the heads, what about pulling the plenum off? -
yobobrox
11:23:52 05/28/08
If you yourself can do so much as remove heads
RedTTZ91(OK)
17:35:48 05/28/08
Actually, I am doing the work myself.
yobobrox
14:35:00 05/30/08
