TwinTurbo.NET: Nissan 300ZX forum - Im pretty sure there is no air in the system but I guess I
Subject Im pretty sure there is no air in the system but I guess I
Posted by 5280Z_nightstalker on May 27, 2008 at 8:49 AM
  This message has been viewed 125 times.
In Reply To How many miles are on this clutch? Did you break it in posted by ThunderZ on May 27, 2008 at 06:44 AM
Message could bleed it again just to be positive. The clutch is brand new and was bought before my build so basically has no more then 10 miles on it from cruising around the block.
Zellamay: There is some free play on the top side of the clutch when I first push on the clutch and from what I know that is normal. I would say about 2 inches of free play on the top side although I need to go push it to be 100% positive and right now its early morning. It fully disengages about a inch off the floor as I said previously and starts to engage probably a inch or two from the top when pushing down. I hope that helps and I guess it does not hurt to just go play with the clutch arm and see what happens. If it gets worse you go the other way right. Was just looking to see if anyone had any idea if that is my problem or not.
