TwinTurbo.NET: Nissan 300ZX forum - Yes that's a good alternative - mine are done that way
Subject Yes that's a good alternative - mine are done that way
Posted by jzack on May 27, 2008 at 8:07 AM
  This message has been viewed 175 times.
In Reply To Is eliminating the knock sensor connector a bad posted by dyno 500 HP 300ZXTT on May 27, 2008 at 01:50 AM
Message too. Just be sure to do a proper job -- don't use the bullet style crimp connectors. Need something more weather tight - use the fully insulated spaded style. Fill up the crimp connector barrell ends with a little diaelectric grease before crimping - makes it more moistured resistant. Be sure to slip some heat shrink tubing on the wire ends before crimping as well -- that will allow a good final seal over the crimp connector ends.
