TwinTurbo.NET: Nissan 300ZX forum - twin gt30r's == sick (n/m)
krazykyle
on May 27, 2008 at 2:14 AM
Im just giving these a try, since i went with octavian
posted by jmurcybizd
on May 26, 2008 at 11:35 PM
Sport 600s upgrade How much boost can i run safely?
jmurcybizd
23:05:19 05/26/08
100% depends on the condition of your motor & supporting
23:16:40 05/26/08
can you see my profile bernie please, so you can see my mods (n/m)
jmurcybizd
23:23:03 05/26/08
intercoolers? (n/m)
23:27:58 05/26/08
Re: intercoolers?
ubermiach
23:30:49 05/26/08
O yeah sorry Fmic from cx racing and stock heads (n/m)
jmurcybizd
23:34:18 05/26/08
Why Front mounts and not sides? I am guessing money?
5280Z_nightstalker
23:54:31 05/26/08
All compression has been tested and its all within specs
jmurcybizd
00:00:30 05/27/08
Re: All compression has been tested and its all within specs
SactoTodd
00:15:46 05/27/08
I also have Mike Smith manifolds as well (n/m)
jmurcybizd
23:45:54 05/26/08
your tubos max at 600 whp so it will be hard to hit
nemo1080 (Iowa)
23:32:41 05/26/08
jmurcybizd
23:35:55 05/26/08
2 cents
ubermiach
23:42:56 05/26/08
I might get that later But for now I want some good boost le (n/m)
jmurcybizd
23:47:48 05/26/08
Why not dyno tune it? (n/m)
SactoTodd
23:52:19 05/26/08
Stock head bolts are stronger than ARP. Believe it or not? (n/m)
phillyz
05:47:33 05/27/08
twin gt30r's == sick (n/m) -
krazykyle
02:14:45 05/27/08
If I had to guess I would say about 22-24 (n/m)
DoodMon(SD)
01:05:59 05/27/08
Any amount of boost over 15psi without a A/F monitor in my
5280Z_nightstalker
08:56:03 05/27/08
Yes i have ngk heat range 8 spark plugs
jmurcybizd
12:11:31 05/27/08
my sport 600 engine did 535whp with mild head porting
SpecNATT (Houston)
20:18:17 05/27/08
don't boost more than 24-25psi ...from personal
The Devils Z
20:24:21 05/29/08
