TwinTurbo.NET: Nissan 300ZX forum - If the 1M OHM resisitor is good, the problem is most likely
Subject If the 1M OHM resisitor is good, the problem is most likely
Posted by ThunderZ on May 26, 2008 at 10:22 PM
  This message has been viewed 109 times.
In Reply To Re: 8 psi boost posted by tsaitang on May 26, 2008 at 06:45 PM
Message in the wiring harness. The break in the wiring can happen when doing a plenum pull, when the harness is bent upward for clearance.
Strip off some plastic on the harness side where the harness would be bent up and see if the wire broke. If so, just re-solder and the code will go away.
