TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Probable damaged exhaust valve on cyl#2
Subject Re: Re: Re: Probable damaged exhaust valve on cyl#2
Posted by JDM300 on May 26, 2008 at 10:08 PM
  This message has been viewed 113 times.
In Reply To Re: Re: Probable damaged exhaust valve on cyl#2 posted by txq45 on May 26, 2008 at 09:12 PM
Message :First 120 lbs per cylinder is low then the 80 lbs on #2.
:Doesn't mean it's a valve. Since all are low to begin with
:and one is at 80 could be rings...but to find out do a leak down test and see where your losing it. also could be a blown head gasket..again the leak down test would show, but in the long run your engine is about gone anyway start thinking about rebuild.
Shop diagnosed as valve
