TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Probable damaged exhaust valve on cyl#2
Subject Re: Re: Probable damaged exhaust valve on cyl#2
Posted by txq45 on May 26, 2008 at 9:12 PM
  This message has been viewed 118 times.
In Reply To Re: Probable damaged exhaust valve on cyl#2 posted by JDM300 on May 26, 2008 at 07:11 PM
Message First 120 lbs per cylinder is low then the 80 lbs on #2.
Doesn't mean it's a valve. Since all are low to begin with
and one is at 80 could be rings...but to find out do a leak down test and see where your losing it. also could be a blown head gasket..again the leak down test would show, but in the long run your engine is about gone anyway start thinking about rebuild.
