TwinTurbo.NET: Nissan 300ZX forum - Re: ignition coil question/problem
Subject Re: ignition coil question/problem
Posted by PULSAR GTR on May 26, 2008 at 8:50 PM
  This message has been viewed 193 times.
In Reply To ignition coil question/problem posted by speedy z on May 26, 2008 at 08:43 PM
Message If you moved the coil to a different cylinder and the problem followed, you definitely have bad coil, you need to fix this asap, otherwise you can potentially damage your PTU module.
I suggest two things, if the coil is leaking from the section where it plugs on the sparkplug, you can wrap electric tape around it to isolate the spark from the hole.
2) better recommendation, replace the coil, if you don't have a replacement, I am pretty sure some local member might have one, I got at least 50 of them lol.
Cheers,
Rafi
