TwinTurbo.NET: Nissan 300ZX forum - Re: HELP!!! Question about CAS and fuel injectors.
Subject Re: HELP!!! Question about CAS and fuel injectors.
Posted by PULSAR GTR on May 26, 2008 at 8:45 PM
  This message has been viewed 120 times.
In Reply To HELP!!! Question about CAS and fuel injectors. posted by ikillastylezi on May 26, 2008 at 06:15 PM
Message Well, that is not the correct way to test your injectors, the manual most likely is refering to test the CAS/spark.
In order to test your injectors, you can do couple of things, you can get yourself an OHM meter, remove the Injector plugs, ohm out the injectors, you should get a reading between 11-14 ohms, any thing above that indicates a bad injector.
Also, you can listen to your injectors firing using few tools, they one that doesn't require you a fancy too, is just a long screw driver, stick it on the top of the injector while th engine is running and you can hear the injector clicking, indicating opening and closing.
Cheers,
Rafi
