TwinTurbo.NET: Nissan 300ZX forum - Re: Probable damaged exhaust valve on cyl#2
Subject Re: Probable damaged exhaust valve on cyl#2
Posted by JDM300 on May 26, 2008 at 7:11 PM
  This message has been viewed 111 times.
In Reply To Probable damaged exhaust valve on cyl#2 posted by JDM300 on May 26, 2008 at 07:09 PM
Message :Cyl #2 is 80psi while others are around 120, wet test made no difference, seems likely exhaust valve. How bad will it be for the engine to operate it like this, and, if not an idication of the other valves failing, how long would it work like this for?
Forgot to mention, power, idling, etc. all seem fine, not much vibration in engine, acceleration good, idle is high though when warm 1.2k and can't get it down again
