TwinTurbo.NET: Nissan 300ZX forum - Fuel system cutting out when cold
Subject Fuel system cutting out when cold
Posted by JDM300 on May 26, 2008 at 7:06 PM
  This message has been viewed 144 times.
Message Hi, my fuel system cuts out causing a stall when cold. Starts up again after 5 seconds. After running for 20min seems ok. Does it if idling or accelerating but will definately do it accelerating while it will idle for minute at a time without stalling. Fuel injectors and pressure regulator tested ok. Possible choices are pump/relay/ecu/fusable link, anything else (other than wiring/grounds)? Which of these are more likely, I am having a shop check the pump but if they don't find anything wrong with it I don't have the $$ to keep paying them as they said it is intermittant so it is quite costly and hard to diagnose.
Thanks!
