TwinTurbo.NET: Nissan 300ZX forum - The BOSE probably sounded better because the
Subject The BOSE probably sounded better because the
Posted by ThunderZ on May 26, 2008 at 8:25 AM
  This message has been viewed 130 times.
In Reply To Re: You are correct! posted by MrPulldown on May 26, 2008 at 01:46 AM
Message Kenwoods might not have been mounted as well. The BOSE in stock form is in a sealed, ported box and has an air-tight mount. Unless you used rope caulk and got a good seal AND used the BOSE box, your sound won't be very good.
Also, IIRC, Bose is 1 ohm.
In your '90, the rears are 6.5", but speedy z has a '92 that uses 3 1/2". 5 1/4" speakers replace the smaller ones perfectly w/ rope caulk as a sealer. The bass is better than the BOSE when you do this.
