TwinTurbo.NET: Nissan 300ZX forum - first I would inspect the wiring to the starter and
Subject first I would inspect the wiring to the starter and
Posted by spyhunterTT on May 26, 2008 at 7:00 AM
In Reply To Electrical gremlin in my z posted by lugerz on May 25, 2008 at 12:33 PM
Message alternator. Replace as necessary and test battery/alternator. If the problem continues, then go through all the fuses and fusible links. Make note of which is burned out. Refer to the FSM under the power routing section to see what powers what. Once you find a common point of failure from the diagrams, trace the wiring. Good luck.
Alex
