TwinTurbo.NET: Nissan 300ZX forum - figured it out
Subject figured it out
Posted by 600ZXR on May 25, 2008 at 10:03 PM
  This message has been viewed 158 times.
In Reply To N/A to TT now key is stuck! any suggestions? posted by 600ZXR on May 25, 2008 at 08:31 PM
Message I hope this helps anyone out there that runs into a similar problem. If you take the steering column cover off then you can see a little metal switch/button right behind the key release button. Mine was painted red. Just push that button and run the key thru each position then remove it as normal. Thanks to those who gave me their 2 cents it helped me think a little more about how the system works and where I should go.
