TwinTurbo.NET: Nissan 300ZX forum - We've done it twice with the engine in ...
Subject We've done it twice with the engine in ...
Posted by IB (Aus) on May 25, 2008 at 9:54 PM
  This message has been viewed 374 times.
In Reply To head removal posted by forced1(nyc) on May 24, 2008 at 10:37 PM
Message A few of the things we do ...
We use an engine crane to raise and lower the head assemblies. They're quite heavy and awkward, especially when you’re trying to lower them gently into position.
Unbolt the oil drain from the turbos rather than pulling the rubber hose off the sump.
On a RHD auto, you need to remove the right dump pipe from the turbo to clear steering and transmission dip stick.
Need to loosen the dip stick from it’s seat in the block before lifting left head, haven’t found a good way of doing that yet.
Good luck,
Ian
Cheers,
Ian
