TwinTurbo.NET: Nissan 300ZX forum - Re: I just went through the issue of an injector failing and
Mike87T
on May 25, 2008 at 5:23 PM
posted by onewheelf4
on May 25, 2008 at 10:06 AM
I guess I need to see if it happens on the same cylinder over and over. If it does, I woudn't mind swapping out an injector. If it switches cylinders would it be worth picking up a used PTU etc?
Possible PTU issue..random cylinder dropping
Mike87T
16:35:02 05/24/08
Yes - dying injectors can fail and then work,
jzack
17:54:36 05/24/08
onewheelf4
10:06:17 05/25/08
Re: I just went through the issue of an injector failing and -
Mike87T
17:23:50 05/25/08
I'd check and verify the wiring before replacing the
jzack
23:31:05 05/25/08
You know that little sub harness on the PTU?
spyhunterTT
06:55:47 05/26/08
