TwinTurbo.NET: Nissan 300ZX forum - The passenger side DP is easy. The driver side DP
Subject The passenger side DP is easy. The driver side DP
Posted by ThunderZ on May 25, 2008 at 7:44 AM
  This message has been viewed 141 times.
In Reply To Exhaust Work posted by SeekingZ on May 25, 2008 at 04:25 AM
Message is the challenge, but I can get to all of these from underneath w/ just basic tools:
13mm shorty wrench
- for top bolt closer to driver side
- for bottom nut closer to center of Z
13mm regular length wrench
- for bottom nut closer to driver side
13mm 1/4" socket w/ u-joint and extensions
- for top bolt closer to center of Z
O2 sensor tool from Pep Boys ($10)
- remove once on vise, tough to remove installed in Z
Anti-sieze/PB Blaster- do as Nixit says.
If the bolts don't give, don't use crazy force or they will break and then you'll be in for a real PIA of a job. Just be patient w/ the PB Blaster- could take a day or 2 of soaking to penetrate enough to prevent broken bolts and studs.
