TwinTurbo.NET: Nissan 300ZX forum - 8 psi boost
8 psi boost
tsaitang
on May 25, 2008 at 7:04 AM
I can only get 8 psi on boost! changed out a broken boost sensor but still know good. any suggestion on wha else to check?
8 psi boost -
tsaitang
07:04:28 05/25/08
Run an ECU diag and see if you have any codes 1st.
ThunderZ
07:38:20 05/25/08
Do a boost leak test. You may have one or more
Audioquest
10:03:44 05/25/08
Re: 8 psi boost
tsaitang
18:45:43 05/26/08
If the 1M OHM resisitor is good, the problem is most likely
ThunderZ
22:22:53 05/26/08
Re: If the 1M OHM resisitor is good, the problem is most likely
tsaitang
08:49:16 05/27/08
Not sure, I never tested it like that. But I was able to
ThunderZ
20:50:49 05/27/08
no more code
tsaitang
14:19:13 05/28/08
Alright, way to fix the codes. Now I'd do what Audioquest
ThunderZ
21:40:10 05/28/08
