TwinTurbo.NET: Nissan 300ZX forum - Two wires total.
Subject Two wires total.
Posted by ni[X]it on May 25, 2008 at 6:53 AM
  This message has been viewed 215 times.
In Reply To Cigarette Lighter wiring 300ZX TT posted by Roy on May 25, 2008 at 03:45 AM
Message Use a volt meter to find which is hot and which is chassis
ground.
I know one of the connecters is a really large black connector. I
believe this is your hot. It goes to the center electrode on the
cig lighter. THe outer shell of the lighter gets the ground.
If you solder it, make sure you use a spade connector so you
can still service your car. Having it soldered to the car
permanently isnt a good idea.
Pull the radio bezel to get to the center console. THen you can
remove it and get to all the wires easier.
Petz #3
