TwinTurbo.NET: Nissan 300ZX forum - Hold a mirror behind the exhaust pipe, after the engine is
Subject Hold a mirror behind the exhaust pipe, after the engine is
Posted by zellamay on May 24, 2008 at 9:51 PM
  This message has been viewed 227 times.
In Reply To weird smoke problem posted by cossiemodo2000 on May 24, 2008 at 12:08 AM
Message warmed up. If water condenses onto the mirror, there is water in your exhaust, which means that you have a bad head gasket, or turbo seal leak. If so, you can have any auto shop test the head gasket, by checking for exhaust gases in the radiator, for about $25 . This will detect a bad head gasket before a compression test will, and is much cheaper.
