TwinTurbo.NET: Nissan 300ZX forum - Possible PTU issue..random cylinder dropping
Subject Possible PTU issue..random cylinder dropping
Posted by Mike87T on May 24, 2008 at 4:35 PM
  This message has been viewed 185 times.
Message So I did headgaskets recently on my 91TT and when I went to start it half the cylinders were out..So I got some dielectric grease and greased up every PTU, CAS, and injector connection. Started the car, everything is great for 2 months on all cylinders. Last night I go to take my first 2 hour drive to the beach since the rebuild and cylinder 4 out of nowhere drops out 15 minutes into the drive. Pull over, and re-dielectric grease all the same connections (keep the grease in my glove compartment) and it still kept missing on #4. So I drive home to switch cars and a mile from my house it ran terrific suddenly on all 6 cylinders again without an issue, so all seems fine. I still took a different car though. This probably will happen again I'm assuming, what do you think I should try? Try another PTU? CAS? I don't think it is an injector since it happens on random cylinders, but if it is an injector, do dying injectors randomly work/not work? Thanks for any input..
