TwinTurbo.NET: Nissan 300ZX forum - Finally found my idle problem!!!!!!!!!!!!!!!!
Subject Finally found my idle problem!!!!!!!!!!!!!!!!
Posted by cossiemodo2000 on May 23, 2008 at 10:55 PM
  This message has been viewed 240 times.
Message After checking an replacing numerous parts, including efi harness, ptu, aac valve, coil packs, battery, hoses, o2 sensors, and etc, the problem turned out to be a slowly failing spark plug!!!!!!!!!!! I was smelling something burning today while driving, and couple minutes later cyl no.2 died, did the balance test, swapped coils and still it would fire, injectors checked out ok, so I swapped the plug with the plug in cyl 1 and then cyl 2 would fire and 1 would not! Its unbeleivable that I never checked them first! They only had about 20,000k on them what could cause one to fail so soon?
