TwinTurbo.NET: Nissan 300ZX forum - Re: smoking 1990 TT..Any ideas on the route cause?
Subject Re: smoking 1990 TT..Any ideas on the route cause?
Posted by Obeeone on May 23, 2008 at 2:13 PM
  This message has been viewed 108 times.
In Reply To smoking 1990 TT..Any ideas on the route cause? posted by eyes007 on May 21, 2008 at 09:53 PM
Message In my experience when cars sit for long periods of time without being started the valve seals can get dry and will leak only on startup for about 5 to 10 minutes then once the hot oil softens them a little they will stop leaking. Blueish/gray smoke is indicative of oil burning. Black smoke is excess fuel and white smoke is of course water. If it is enough oil in the cylinders it will foul the plugs a little and of course make your car run really rough for a while until the oil gets burned off. As far as the heating problem I'm not sure about that one possibly the coolant temp sensor. Valve seals is a likely possibility though for the smoke.
