TwinTurbo.NET: Nissan 300ZX forum - Adjusting the NA clutch per FAQ write-up...still not good
Subject Adjusting the NA clutch per FAQ write-up...still not good
Posted by enthuZiast on May 22, 2008 at 4:22 PM
  This message has been viewed 161 times.
Message The "grab" point of the clutch has been high and I want to lower the "grab" point via adjusting the rod. I've adjusted the clutch by rotating the rod going into and out of the clutch master cylinder in small increments and the height of the "grab" point of the clutch hasn't moved at all.
The throw of the clutch pedal is getting shorter or longer after adjusting the rod so I know adjusting the rod is physically doing something, but the "grab" point is still high.
To make things more hectic, the clutch is starting to slip under load going up hills but is fine on flat ground.
Am I adjusting the rod correctly? or am I experiencing signs of a clutch on its way out?
Thanks in advance.
<<< Slow in & Fast out >>>
