TwinTurbo.NET: Nissan 300ZX forum - Freeze 12 is 80% R134a, 20% R142b
Subject Freeze 12 is 80% R134a, 20% R142b
Posted by aliaZ on May 21, 2008 at 11:47 PM
  This message has been viewed 400 times.
In Reply To I recently did mine with Freeze 12. No parts to replace if posted by Audioquest on May 21, 2008 at 08:44 PM
Message it won't blow as cold as R-12 unless you gut the TSV.
The purpose of the R142b is to make it compatible with the mineral oil that is used in R-12 systems. If you have a leak, the R142b will leak out first because it is lighter than R-134a. This will cause your compressor to seize from lack of lubrication.
Also, compressor warranties are void with all refrigerant blends.
