TwinTurbo.NET: Nissan 300ZX forum - My input...
Subject My input...
Posted by ThunderZ on May 21, 2008 at 9:27 PM
  This message has been viewed 137 times.
In Reply To About to do the timing belt (120k) am I missing anything? posted by turbo1 on May 21, 2008 at 03:43 AM
Message 1x Timing Belt
2x Water Hoses
2x Crankshaft Sprocket Plates
1x Timing Belt Main Spocket
1x Water Pump
2x Camshaft O-Ring Seals
4x Camshaft Oil Seals
2x Tensioner Springs
1x Timing Belt Tensioner
1x Thermostat
1x Front Crankshaft Oil Seal
1x Idler Pulley
1x Secondary Idler Pulley
3x Drive Belts (A/C Compressor, Belt Fan & Alternator Belt, Power Steering Pump Belt)
Add:
Upper Radiator Hose
Lower Radiator Hose
Both Heater Hoses
1 extra Crank sprocket
1 extra Cam/Crank seal
Radiator if not effective
Clutch Fan if not effective
Fan if cracking
Fuel line for front fuel rail connection
4 PCV hoses- all except rear
2 PCV Valves
O2 sensors if sweeping slowly
6 Spark plugs
I go a little overboard, but the way I see it, I'd rather do this maintenance in my garage than on the road.
