TwinTurbo.NET: Nissan 300ZX forum - Check your battery terminals, make sure they are not corrode
Subject Check your battery terminals, make sure they are not corrode
Posted by Ashman2k2 on May 21, 2008 at 6:27 PM
  This message has been viewed 120 times.
In Reply To Don't know what else to check!!!!!!! posted by cossiemodo2000 on May 20, 2008 at 01:55 AM
Message and are tight. Grind away the paint behind the point where the negative cable attaches to the firewall...I would recommend a ground net in the engine bay just to be sure. As others said have the battery tested obviously. After this then is when I would check the relays, and last the ignition key assembly itself. Also consider that if the PRVR is deleted then it may take longer to start after the engine has been off and warm. Oh and at least try to respond so we don't feel like our suggestions were useless.
