TwinTurbo.NET: Nissan 300ZX forum - Yes, it's not adjusted right. First, bleed the system
Subject Yes, it's not adjusted right. First, bleed the system
Posted by Audioquest on May 20, 2008 at 10:04 PM
  This message has been viewed 144 times.
In Reply To thanks guys in regards to the tranny oil fill question. posted by pearlyellowtt on May 20, 2008 at 09:34 PM
Message at both points, the fender nipple first, then the slave cylinder. Once that's done and you are 100% sure all the air is out, set it up.
This is a good writeup and the only right way to do it:
[ http://www.twinturbo.net/nissan/300zx/forums/technical/view/880853/Correct-Clutch-Pedal-Adjustment-for-High-Per-Clutches.html ]
