TwinTurbo.NET: Nissan 300ZX forum - Maximum combined limit is .2 MM, or .008 in.
Fast300
on May 20, 2008 at 10:01 PM
Are you sure those numbers are correct?
posted by scottyfender
on May 20, 2008 at 10:21 AM
If his .03 is a measurment in mm, then the combined of .06 mm is ok.
If the .03 is in inch, that is 1.52 mm, well over seven times over the limit.
Clerance Question
300znick
20:17:52 05/18/08
It all depends on the thickness of the gasket and
Fast300
00:25:26 05/19/08
Re: It all depends on the thickness of the gasket and
300znick
09:58:45 05/20/08
scottyfender
10:21:01 05/20/08
Maximum combined limit is .2 MM, or .008 in. -
Fast300
22:01:38 05/20/08
So my combined .019" isn't going to work even if I...
scottyfender
23:01:57 05/20/08
Those are the factory specs, make your own conclusions (n/m)
Fast300
16:50:38 05/21/08
