TwinTurbo.NET: Nissan 300ZX forum - Piston-to-bore clearance is supposed to be .0025"
Subject Piston-to-bore clearance is supposed to be .0025"
Posted by na300zx (OH) on May 20, 2008 at 6:19 PM
  This message has been viewed 485 times.
In Reply To Wiseco supplied rings - end gap posted by Bezza on May 20, 2008 at 10:02 AM
Message Your cylinder is too big, and that is probably why you are having trouble with the rings. I would recommend going to .040" over at this point. If you stick with .020" over you will probably have a lot of piston slap and your engines life will be shortened.
