TwinTurbo.NET: Nissan 300ZX forum - Re: Can the heads be removed with the turbos and manifolds a
treese88
on May 20, 2008 at 4:24 PM
Can the heads be removed with the turbos and manifolds attac
posted by jmurcybizd
on May 18, 2008 at 11:57 AM
If you are going to pull the heads you are best off pulling the engine. You can leave the turbos attached; there are a few oil lines to disconnect.
'91 TT Project build: In progress
jmurcybizd
11:57:39 05/18/08
txq45
14:05:53 05/18/08
Thank you sir Ill get started right away :) (n/m)
jmurcybizd
16:26:14 05/18/08
Yup-thats what I just did to replace head gaskets..
Mike87T
22:25:09 05/19/08
Re: Can the heads be removed with the turbos and manifolds a -
treese88
16:24:58 05/20/08
