TwinTurbo.NET: Nissan 300ZX forum - Re: did u check ur ptu?
Subject Re: did u check ur ptu?
Posted by blink2401 on May 19, 2008 at 2:40 PM
  This message has been viewed 123 times.
In Reply To did u check ur ptu? (n/m) posted by cossiemodo2000 on May 19, 2008 at 03:05 AM
Message I relocated the ptu to under the nose panel about three years ago. I checked the wire loops and I do not see any problems with the wires.
I gave the connections a wiggle, cleaned them out and tried to turn the car on again and same problem, It sounds like it is going to start, then it dies. If I keep the key turned it will keep trying to start but never seems to catch.
I checked the fuel line after the fuel filter and turned the key, fuel came out so that is not the the problem.
I also checked one of the coil packs and turned the key and saw voltage spike, I did not catch what it was spiking to but at least that means voltage is going to the plugs.
Any ideas on what to check? Anyone know of a reputable place to take the car in the Tucson area?
