TwinTurbo.NET: Nissan 300ZX forum - There are two inlet options with the Derale trans cooler
inferno
on May 19, 2008 at 6:31 AM
5/16 is 7.93MM, that is closer to 8MM than 6MM
posted by Fast300
on May 18, 2008 at 12:49 AM
The cooler core of model 13900 has AN-6 (3/8” ID) inlets and hose barb adapters are included to hook up non -AN type hoses. The other model, 15900, has AN-8 (1/2” ID) inlets.
Automatic transmission radiator specs needed
inferno
10:58:38 05/17/08
Re: Automatic transmission radiator specs needed
txq45
11:21:24 05/17/08
Thanks for the info! The reason why I ask is because
inferno
11:52:50 05/17/08
Fast300
00:49:33 05/18/08
There are two inlet options with the Derale trans cooler -
inferno
06:31:26 05/19/08
OK, but the two small pipes on the radiator are still 8MM
Fast300
14:21:47 05/19/08
You are right. I did not phrase my question correctly
inferno
16:23:52 05/19/08
The 3/8 is close enough. (n/m)
Fast300
20:30:05 05/19/08
Thanks, I appreciate the feedback. (n/m)
inferno
03:58:38 05/20/08
