TwinTurbo.NET: Nissan 300ZX forum - Transmission Problem Cont'd
Subject Transmission Problem Cont'd
Posted by BlackTT91 on May 18, 2008 at 4:47 PM
  This message has been viewed 144 times.
Message My transmission is slipping and not shifting into overdrive as ive explained in my previous posts. Ive changed the filter and fluid and also done the diagnostic. Fluid and filter change did nothing really it didnt slip as much i guess but still would not go into overdrive.
The diagnostic came back with nothing everything electrical was fine.
As of right now im going to get under the car again and clean everything up to track down the leak. But im going to tighten the two lines going to the radiator while im at it and tighten all the bolts on the transmission fluid pan.
I dont really know what else to do after this so do you guys have anymore leads? Is it possible my transmission crapped out on me?
One last thing how tight do the pan bolts need to be, when i took them off they were relatively loose anyway.
Thanks for the help again
  • Transmission Problem Cont'd - BlackTT91 16:47:12 05/18/08
