TwinTurbo.NET: Nissan 300ZX forum - PTU could be going bad......
Subject PTU could be going bad......
Posted by Buzz on May 18, 2008 at 3:11 AM
  This message has been viewed 162 times.
In Reply To Re: Check the PTU for bad connections as well.. posted by Vette Killer Z on May 17, 2008 at 05:21 PM
Message You will probably need to replace the PTU. Transistors can become more heat sensitive as they age. Did a search for "ptu failure" and found two posts that should help you.
[ http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=1025526&forum=technical&dtSearch=15 ]
[ http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=910281&forum=technical&dtSearch=16 ]
