TwinTurbo.NET: Nissan 300ZX forum - 90 zx automatic non turbo starting issues.
Subject 90 zx automatic non turbo starting issues.
Posted by Artemas13 on May 16, 2008 at 6:08 PM
  This message has been viewed 119 times.
Message I searched, found nothing, maybe I missed a post, who knows.
I drove the Z for the first time after winter (I winterize properly) and it drove great. Made three stops, started fine each time. Stopped again, and needed to back up and just put it in neutral and let it roll back a few feet, park, key out, later, the Z would not start. It makes a single "tink" noise and nothing more.
The battery is good and fully charged, + and - terminals solid with no corrosion. The battery cables are new. Starter relay is new, and now... so is the starter. Same sound, same problem.
I ran a jumper cable from the - terminal to the block. Still no joy.
I am at a loss here and hopefully someone has seen or heard of this before and knows why it is happening.
I can also be reached on Yahoo messenger: smcginty013
Thank you in advance.
