TwinTurbo.NET: Nissan 300ZX forum - I would run a tranny diagnostics and see what codes you get
Subject I would run a tranny diagnostics and see what codes you get
Posted by keffboyer2000 on May 16, 2008 at 5:27 PM
  This message has been viewed 157 times.
In Reply To please check out my symptoms i tried hellllp !!!!!! posted by dreamchild128 on May 16, 2008 at 01:12 PM
Message I would also check your throttle possition sensor and make sure it is set at .45 volts at idle and 5.0 volts at wot. I think your transmission shifts, rely on this sensor to shift properly and at the correct rpms.
