TwinTurbo.NET: Nissan 300ZX forum - This is after doing an NA to NA swap on a 2+2.
Subject This is after doing an NA to NA swap on a 2+2.
Posted by enthuZiast on May 15, 2008 at 7:26 PM
  This message has been viewed 126 times.
In Reply To Can you tell if the idle is increasing to compensate for posted by Dave N on May 15, 2008 at 07:15 PM
Message yes, there was some access. belts that were adjusted.
I sprayed wd40 into the idle control valve to clean/loosen/lube the insides while the car was idling.
This helped the idle as it is consistently below 1K during idle and smooth. The idle does compensate for the A/C being on and I do not think its because of a low idle that is causing the vibration.
Thanks for the reply.
<<< Slow in & Fast out >>>
