TwinTurbo.NET: Nissan 300ZX forum - so it definately seems like the smoke is blue.
Subject so it definately seems like the smoke is blue.
Posted by pearlyellowtt on May 15, 2008 at 6:54 PM
  This message has been viewed 135 times.
In Reply To need your guys help ASAP posted by pearlyellowtt on May 15, 2008 at 05:53 PM
Message the weird part is that the car runs smooth. the problem showed up when i got rid of the aiv and egr vacuum lines and solenoids. Someone said to cap off the pass side throttle body and intake tube nipples. It actually seems like it lost a bit of power when i did that as well. To my knowledge i did the procedure correctly. i took out all the lines and solenoids, connected the oem boost gauge tube straight to the balance tube, capped the throttle body and intake nipples and the only ones left were the ones that look like where the aiv runs over to the drivers side fender well and originally teed to something else by the battery which i capped off as well. Would this cause this issue?
