TwinTurbo.NET: Nissan 300ZX forum - Re: More Transmission Problems
Subject Re: More Transmission Problems
Posted by txq45 on May 13, 2008 at 10:03 AM
  This message has been viewed 147 times.
In Reply To More Transmission Problems posted by BlackTT91 on May 13, 2008 at 01:59 AM
Message Two lines coming out of your trans to cooler ..
Both are low pressure but will cause a mess.
Fluid should be PINK if you changed it ... easy to notice over engine oil - coolant.
The lines are solid. I suspect you have a leak around the trans oil pan..It's common.. go back and re-tighten the 10mm screws.. If you can't tell when they're tight get a torque wrench .. these screws twist off easily.
